TPS23754: schematic review
Part Number: TPS23754
Pls check the schematic. We use a 8-port POE swtich connect indoor access point. It is VS1008FP . One or two AP can reset if connect eight  AP to the POE swtich. The AP power consumption is 4w on idle.
    So the PD's have no issues with detection and class with the switch? It sounds like a switch issue. Like either the power supply of the switch is having problems providing the startup power when the 8th PD is connected. Or perhaps the PSE has some power management that causes this?
