Hi ,
I am using TPS65910A3 to design my power system.
I have one key(or two keys ) use as a power on (power off) key.
Should I connect the button to which pin of TPS65910A3?
Thank you so much.
Hi ,
Thank you so much.
Hi Shanqing Liu,
A push button can be connected to the PWRON pin, pin 33 of the TPS65910xx. You can refer to page 49 of the TPS65910x datasheet for further information. You can use a single key to turn the PMIC on and off. A short press results in a transition from an OFF-to-ACTIVE or SLEEP-to-ACTIVE state. A longer push button press will force the PMIC from an ACTIVE-to-OFF state. Does this answer your question?
-Raymundo Hernandez-Toscano
