Hi, Is there layout example of color version? We found layout example in EVM user's guide. But our customer wants more cleary it.
tateo
tateo
Thank you for your reply. Let me confirm GND connection of EVM. They consider to refer to board layout of EVM.
- Where is the point that connecting analog GND and power GND of EVM?
I think it is under the thermal Pad. Is it right?
- Which layer does it connect power GND to analog GND? I think it is only 2nd layer. Is it right?
- They would like to know that what type of the each solid GND either analog GND or power GND. I think that it is as follow:
Top layer: Power GND and Analog GND *These GND are separated
2nd layer: Power GND and Analog GND *Tehse GND are connected under the thermal Pad
3rd layer: Power GND and Analog GND *These GND are separated
Bottom GND: Only Power GND
Is it right? Could you check the following comments?
tateo
