Hello.
I'm using a uC to control the BQ78350-r1 via SMBus.
I've succesfully programmed via SMBus all the parameter and settings i need except the chemistry. So far, i've programmed the chemistry through BQStudio and EV2300 only.
My question is: would it be possible to program the chemistry from my uC (as i already do for other registers)?
What are the registers related to the chemistry? Are they documented somewhere? How the extract the chem data for a given ID from the database?
Thank you in advance for your kind help!
