Hi
At Figure 5-5 on the datasheet, PWRHOLD goes high after TdSONT and TdONPWRHOLD.
On the other hand, PWRHOLD is pulled up to VIO(1.8V) by pull-up resistor on our configuration. So, PWRHOLD goes high automatically when the VIO started up.
Is that ok?
On the following timing sequence it looks that we should set this pin to high by external GPIO after TdSONT and TdONPWRHOLD.
Koji Hamamoto
