Hello Team,
We are using TPS54386PWPR to generate 2.5V and 1.8V from 5V,
How much inductor value i must choose for proper functioning.
Please help me for the selection of inductor.
Prasanna G
Hello Team,
Prasanna G
Generally, you design based on your actual load current. The design example uses 2A output for each channel and 30% ripple current for a total ripple of 600 mV. If you are designing for a current way less than the 3 A total, then the inductor value can get quite large. TPS54386 is a non-synchronous converter. If the inductor current falls to zero it will operate in discontinuous conduction mode (DCM). It is perfectly ok to operate in that mode, but some like to avoid it. In that case the criteria is the the p-p inductor ac ripple should be less than 2 times the minimum load current you expect.
