Other Parts Discussed in Thread: LP2985, LP2985-N,
My application uses the TPS71733 to power an MCU. During MCU programming the MCU will be powered directly from the programmer, therefore the output of the regulator will see 3.3V from the programmer and the input will be at 0V.
Should I be using a reverse current protection diode similar to what is recommended for the LP2985? As shown on page 18 of the LP2985 datasheet http://www.ti.com/lit/ds/symlink/lp2985-n.pdf
Thank you,
Adam
