Other Parts Discussed in Thread: TPS54202
I am using TPS54821 IC to step down +12VDC Voltage to +5V, the IC perform well for high current, has very low drop and produce very less Heat. But It has no short circuit protection if I accidentally connect output to ground IC is getting damaged. How can i solve this?
Is there any short circuit protection circuit? which has to be faster then damaging of ic.
Data sheet says IC has Hiccup protection !!
Thanks and Regards,
Surjit
