Hi Team,
My customer has UC2842A output pin damaged issue in their factory. The fail rate is not quite high but they still want to find out the root cause and did some experiments.
Attached are a circuit and a waveform of OUTPUT pin. The supply voltage of VCC is 17V, the OUTPUT pin has a short spike voltage around 18.96V that might caused by transformer's back EMF. We can found the spike voltage seems to be clamped by ESD diode. Customer wants to know the around 2V spike voltage with 9uS duration will have risk to damage the device or not?
Thanks very much.
Vincent Chen
