Other Parts Discussed in Thread: AM3356
Vsys set up is 5V, When 5V<Vsys<5.37V ,TPS65218 can start up and work normal, when 5.37V<Vsys<5.5V, DCDC6,DCDC5,LDO1,DCDC3 Power-Up Sequence start up ok, when come to DCDC4,can't start up,then the TPS65218 restart. if reduce the Vsys to 5V online, the TPS65218 can start up and work normal. if increase Vsys to 5.4V after start up, TPS65218 can work normal.
Vsys=5.4V,start up, green is Pin13(L4A),purpleis is Pin17(DCDC4)TPS65218_DEBUG_SCH.pdf
