BQ24195: pull-up resistor for STAT pin
Guru 29720 points
Part Number: BQ24195
Hi Team,
The datasheet shows "Connect to the pull up rail via 10-kΩ" for STAT pin.
On the other hand, 9.2 Typical Application (page.34) shows 2.2kΩ for pull-up resistor.
Which do you recommend?
Is there minimum value?
Yaita / Japan disty
