We are using TPS68233 on our board. After we receive boards from automated reflow soldering process, we notice that more than half of TPS68233's provide wrong output voltage, most of them at 1.6v OR 1.7v. When we desolder and replace newer one by soldering manually, we get correct output, 3v3.
We checked device marking as well, "OAH", which is correct. What is the problem here? Should we check reflow temperatures or do you have any other solution?
Thank you.
