Other Parts Discussed in Thread: CC1310, , TPS62740, TPS61291
I'm looking for a power solution for my ultra-low power IoT application based on the CC1310.
- I'll be using a LiSOCl2 battery, so can expect an input voltage range of about 3.0 to 3.7V.
- I am trying to get a consistent, efficient 3.3V output with about 100-200mA.
- Since it's a low power/mostly sleep mode device I need a quiescent current < 2uA
I stumbled across the TPS610981 but I'm having a hard time distinguishing it from other parts in the same family. In the datasheet it has a device comparison table, but I'm struggling to understand what each column means.
Could someone explain to me the meaning of the columns in the table on page 3 (http://www.ti.com/lit/ds/symlink/tps62730.pdf)
Also, are there any other parts or combination of parts which may fit my regulation requirements?
