Other Parts Discussed in Thread: LM5069
In the schematic attached the IMON output of the TPS2493 goes to the RTN pin when there is reverse protection between the chip ground and actual ground. My question is, do you have to then differentially read the current feedback or under real conditions is the voltage differential between GND and RTN small enough or predictable enough to calculate out?
Thanks!
