bq34z100-G1: bq34z100-G1
Part Number: BQ34Z100-G1
Does the HDQ interface support multiple slaves ?
  • Hi Vi,
    A passive pullup resistance is required to pull the HDQ line to a high state when neither the host nor the slave is pulling the line low
    during the two-way communication over the single wire interface. Meaning that as long as you are pulling up to the appropriate "high level" you should be able to hang multiple slaves off this bus.
    Siby
