Part Number: BQ51013B
Hello all,
I am currently trying to get a custom system with the BQ51013B up and going. Unfortunately the out put from the BQ51013B is not looking quite right. I have attached oscilloscope prints of the OUT signal and the RECT signal. I came across this thread and went through the items discussed there. I have found that the capacitors for the CA1 series are 0402's instead of 0603's. I am now going through and double checking our measurements and calculations for C1 and C2 as detailed in equation 6 of that data sheet. Based on the behavior seen below, is there any where else anyone would recommend to investigate first?
Eric
Figure 1: OUT
Figure 2: RECT
