Configuring TLC59401 using FPGA
Other Parts Discussed in Thread: TLC59401, TLC5940
hi,
    i am planing to drive TLC59401 using FPGA. will u please help me coding verilog to drive TLC59401
praveen
  • Hello Praveen,
    What help are you searching for? I am not experienced in coding Verilog, but maybe I can help to understand the functionality of TLC59401 in detail. So if you have questions to the functionality of the part, please detail these and then I can try to help you.
    Brigitte
  • hi,
                will you please  explain me the  Architecture of TLC59401 IC. my contact number is : 9866339896. i want to drive a rgb led display board htrouh FPGA. for that i wrote a code but i was unable to drive up my board.
    praveen
  • Hello Praveen,
    What do you mean with architecture? For a lot more technical information then in the TLC59401 product folder, please review the EVM document and the application notes you can find in the TLC5940 product folder. Maybe this helps to solve your issues. TLC5940 and TLC59401 are almost identical, the only difference is the drive current and TLC59401 does not have an EEPROM.
    Brigitte
