Other Parts Discussed in Thread: TPS62135
We are using TPS62110RSAT, the configuration is standart step-down, VIN=13V, VOUT = 7.7V. In this state, the SW output is supposed to switch from GND to VIN, but we see that if the converter enters Current Limiting mode, SW switches from GND to an intermediate voltage (see scope image below).
Is this normal behavior of the converter in current limitation?
Thank you
Eli.
