TPS54821: Dead Time ; Efficiency calculation including Bottom FET switching and
Part Number: TPS54821
Other Parts Discussed in Thread: TPS54824, TPS549A20
Per Equation 10 at this link: http://www.ti.com/lit/an/slyt664/slyt664.pdf
I would like to roughly budget the power lost in the bottom FET body diode in the TPS54821 and TPS54824 and TPS549A20.
What are approximate values for the inputs to this equation for low side FET for these devices. Nothing is specified or charted.
Just first order values are fine.
Vout is 0.8V.  Does this low voltage impact the loss in the bottom FET\diode as drain to source is low?
