Team,
The datasheet pin description for COMP2 and COMP4 states the line should be pulled up to VDDD for phase interleaving. However, the description later in the datasheet says to use a 4k to VDDA.
The EVM uses a 1k to VDDA. Is one method preferred over the other? If so, the description should be consistent in both sections of the datasheet. This is applicable to the TPS65400-Q1 datasheet also.
Thanks!
Phil
