TLC59116: TLC59116 vs TLC5971
Part Number: TLC59116
Other Parts Discussed in Thread: TLC5971
Dear Sir
May I know what's the benefit of TLC5971 ??? compare with TLC59116
I saw TLC5971 have "Grayscale (GS) Control With Enhanced Spectrum PWM:16-Bit (65536 Steps)" this feature
But I have no idea what's application have to use this feature ,if you have document to describe ,please kindly let me know
  • Hi Kai,
    Sorry for the late response. The appropriate application engineer has been notified of your post and will respond accordingly. Thanks for your patience.
    Shirley He
  • Hi, Kai,
    TLC5971 uses serial input interface which has higher data transfer rate comparing with TLC59116 which uses I2C.
    As for Enhanced Spectrum PWM (ES-PWM), it can significantly increase visual refresh rate in multiplexing applications.
    Hope this will help.
    Kenneth
