Part Number: TPS53318
Other Parts Discussed in Thread: 66AK2H14, TPS54318,
I am using TPS53318DQP regulator to generate 1.8V. I am using this to supply five 66AK2H14 processors and few other ICs (total current required is 6.5A approx.).
The processor datasheet suggests to put many number of capacitors for each supply. Since the same regulator is shared, there will be a huge number of capacitors ( as decaps/bypass caps) at the regulator output.
So please let me know is there any maximum limit for number of decaps/bypass caps at each regulator output. Also, I have added each IC maximum current consumption and selected the regulator. Please let me know is there any other parameter to be considered while selecting regulator for these kind of applications.
Thanks in advance.
Madhu.
