Hi~
In LM25118-Q1 datasheet, supportable topology is just buck or buck-boost topology.
But when output is always higher than input voltage, it always works as boost, so it looks no problem? am I right?
And then can I use just boost only mode by removing hi-side FET(HO FET)?
If possible, just open HO pin is possible? (VIN connect to HS directly by removing hiside FET.
Thanks for any advice.
