Hello
I need to drive two different MOSFETs( not half bridge), one high side and one low side( where the drain of the second MOSFET is connected to the Drain of the first). This is for a PFC followed by a buck converter.Hence the two MOSFETs sharing a common Drain voltage.
I wanted to know if TI has any integrated solution for driving two MOSFETs as I have explained, without them having to be in a half-bridge config.
Also, does TI have an integrated current shunt sense amplifier in any of these solutions to the above issue.
Thanks.
