Other Parts Discussed in Thread: LM25066EVK, LM25066
Is it appropriate to power the VDD pin with an external supply of 5.5V while the LM25066A is in normal operation with VIN = 12V?
The datasheet shows that the VDD pin can handle up to 6V, but just want to make sure that applying an external voltage higher than the sub-regulation voltage does not result in any negative effects.
