Other Parts Discussed in Thread: TPS63070
Hi
Our customer are considering about external softstart. I refereed the following a document and post. Then I suggested adding the external softstart circuit to our customer.
http://www.tij.co.jp/jp/lit/an/slva553/slva553.pdf
Regarding discharging, they do not want to add the discharge resistor because of output accuracy. And they added a diode to between C5( SS circuit cap) and ground.(see the following)
What do you think the above configuration should work?
Koji Hamamoto
