LM2676SX-ADJ/NOPB
hi TI,
my question would be generic regarding combined lot or date code marking on the TI reel label. would you let me know how many combined date code can be within 1 packaging unit?
if TI label indicates 2 date codes inside, does it mean I will find 2 date codes, or it possible only 1 date code inside?
is that possible if secondary date code marked on the label, but only 1 date code had been packed by TI?
thanks
Adrianb
  • Hi Adrianb,
    Please allow us some time to look into it. Will get back to you soon.
    Jason Song
  • hi Jason,
    do you have any update?
    thank you!
    Adrian
  • I will pass this along to the PE for this product.
  • Hi Adrian,
    Sorry for the late reply. If the label is showing 2 different date codes then my guess is there are 2 different date codes of material in the reel. If you can provide a  a picture of the reel label we can look up the information based on the STC to fully confirm, but I suspect we will reach the same conclusion.
    TI can combine up to 4 different date codes (no more than 1 year apart) AND up to 24 LTCs into a single reel.
    Jason Song
  • Reply from packaging:
    Answer: Maximum 4 date codes, not more than 52 weeks apart, may be combined into one intermediate manufacturing pack (bag/box/reel).
    Answer: If 2 date codes are indicated on the label then the manufacturing pack will contain 2 date codes. Conversely, if 1 date code is indicated on the label then only 1 date code will be present in the manufacturing pack.
    Answer: If the label indicates multiple date codes in the pack, then there should be more than one date code in the pack.
