Other Parts Discussed in Thread: TPS54302
1. My customer used TPS54302EVM test (no change, all using EVM original setting), they found static load but switching Frequency is shift around 360kHz~400kHz,
Is it normal? If yes, could you explain why caused switching frequency shift? You can refer to below attach file.
2. If load a over 2A loading at output side, than start up the TPS54302, it will boot up long time, seems trigger some protect, could you please help to check why cause it?You can refer to below attach file.
This EVM is no any change, all using EVM original setting.
