Tool/software: Linux
Hi All,
I am trying to integrate the LP55231 linux device driver with our ARM based board running openwrt. I am able to see /sys entries but when i try to load firmware i see the following error.
[ 6219.827586] lp5523x 0-0032: Direct firmware load for lp55231 failed with error -2
[ 6219.836484] lp5523x 0-0032: Falling back to user helper
I am trying to load the firmware with the following commands:-
echo 3 > /sys/bus/i2c/devices/0-0032/select_engine
echo 1 > /sys/class/firmware/lp55231/loading
echo "9d0740ff7e0040007e00a0010000" > /sys/class/firmware/lp55231/data
echo 0 > /sys/class/firmware/lp55231/loading
echo "000001100" > /sys/bus/i2c/devices/0-0032/engine3_leds
echo 1 > /sys/bus/i2c/devices/0-0032/run_engine
The following forum https://e2e.ti.com/support/power_management/led_driver/f/192/t/421131
Can someone help here?
Aravind
