TPS546C23: TPS546C23
Part Number: TPS546C23
Hi;
Could you please tell me how the I-share circuit works with 1pin in 2 phase application?
As I understand, both master and slave do the current share/balance.
The I-Share pin should send the current to the other block and also receive that; how do we do that with 1 pin and analog signal?
The circuit is not described in the datasheet.
Thank you.
