The two available packages, 3.5x3.5mm with a 2x2mm thermal pad and the 5x5mm with 3.15x3.15mm thermal pad have the same die.
Incrementally better thermal performance of the bigger thermal pad would be expected - and it is for Roja and Rojc(top). However the situation is reversed for the Rojc(bott) which is counter-intuitive.
Is this correct and how do I explain it
Thank you
