TPS55010: Calculating maximum output level
Part Number: TPS55010
Is there a way to calculate the maximum level the output of the TPS55010 secondary could drift up to when unloaded and used in a standard flybuck configuration?  My customer has an LDO follower and wants to make sure the input voltage range of the LDO is not exceeded when unloaded.  I can share the exact schematic and coupled inductor spec.
Dan
