BQ76930: parallel FET.
Part Number: BQ76930
Other Parts Discussed in Thread: TIDA-00449
Hello Everybody,
I'm developing the 6S BMS BQ76930. I saw on the site of TI a document with a recommendations on parallel connection of FET.(charge, discharge).
Now I can't find this document.
Please help me to find this document.
BMS have to be a ring. I want to use the surface more efficiently.
Thank you.
Andrew.
  • Hi Andrew,
    I'm not sure I understand correctly.
    The TIDA-00449 uses parallel FETs and its design guide section 4.1.3.2 has a brief description. Most FET manufacturers have a writeup about paralleling FETs and recommend some separate gate resistance.
    If you are considering parallel charge and discharge paths, this e2e post may be helpful. e2e.ti.com/.../1348804 Connecting a discharge path at the common drain of the low side FETs retains discharge protection for the charge path, but the discharge path would not be protected against charge.
