TPS63000 and Multiple Li-Ion Batteries
Other Parts Discussed in Thread: TPS63000
The TPS63000 explicitly says that it is only for use with a single Li-Ion battery...
But what should I do if I need to have three Li-Ion's in parallel to have my system operate as required?
Perhaps a naive suggestion: but could I have three TPS63000 circuits (one for each battery) with the outputs of each circuit connected? Or would having the three batteries, with some sort of diode in series with each to prevent charging, be appropriate?
Thank you for reading this post.
