I have our first prototypes of a 35A 2-phase TPS53647 design. I am connected to it with TI Fusion Digital Power Designer. I have a "RST_VOUT Fault" in the status registers that won't clear. In the data sheet, the STATUS_MFR_SPECIFIC register contains this field and it says that it indicates a RST_VOUT fault has occured, but it doesn't say want an RST_VOUT fault is. I haven't been able to find an explanation for what this fault means in the the TPS53647 data sheet or searching. My questions are
1. what is a RST_VOUT Fault?
2. Where would this information be in case I need to find definitions for other faults, i.e. VSNSGT2P75FLT?
Thanks much.
