Testing of UC1834J
We tested the parts, UC1834J,at different temperatures with an voltage of 2V, the results were not consistent to that of the "J" package for the TL1451 specs. At -25 to -45 degrees the stability of the IC was very inconsistent, as for the 25 to 125 degrees the IC stayed stable without major fluctuation.
Could you explain the reason behind the instability of the test in cold temperatures?
Thank you,
Jesus
