Can LMR16006 be broken by small(15nF) boot strap capacitor?
I and my customer are considering for the cause of broken.
Kuramochi
Kuramochi
I don't think low boot cap will damage the part, but 15nF is too samll, it will turn off the high side FET when the CB to SW pin voltage is below 3 V no matter what's the value of the D (the detail you can refer to the section 8.3.2 in the datasheet). So if your convert has a big D, an enough cap is needed.
Furthermore, the voltage rate of the cap must have the margin, 16V is enough.
