It is mentioned follows on the datasheet.
"If the use of a higher voltage is desired due to system or other constraints, a 100 kΩ or larger resistor is recommended between the applied voltage and the SHDN pin to protect the device."
What do you mean "to protect the device"?
Can the device be broken without a 100 kΩ or larger resistor?
I have already seen follow thread.
Kuramochi
