BQ34Z100-G1: BQ34Z100-G1 UNSEAL PROBLEM
Part Number: BQ34Z100-G1
Dear All,
I can access data flash and all standard command.but my problem is when access data flash,two times i unseal the device then only i can read the data flash register.otherwise it will shows the zero.
  • Arun
    That is how the gauge is designed to operate. Once you seal the device you can never permanently go to unseal state by using the unseal codes. you will have to reprogram the gauge with the default srec to be able to be in a permanently unsealed state.
    thanks
    Onyx
