Other Parts Discussed in Thread: TPS2413, TPS2419
Hello All,
One of our customers wants to use BQ24166 for his design and he has the following questions
1. Can it be used without a battery? There are some cases where he does not want the battery connected and just use it like a switch mode buck from the supply to feed to system load.
2. In same cases, he wants to use several BQ24166 in parallel to charge batteries (1 battery per charger). Will he encounter any problems by paralleling these devices?
Are there newer devices or better devices in your mind that can accomplish this application?
Best regards
Anil
