I have a question about TPS54320.
In TPS54320 datasheet, it said if an application requires controlling the EN pin, use an open-drain output logic to interface with the EN pin.
If we want to controll the EN pin by the external signal, can we input High/Low signal directly to the EN pin?
Do we need a pull down resistor at EN pin?
Thanks.
