TPS54561: shutdown
Part Number: TPS54561
We need to enable and disable the TPS54561. However, the enable-pin is too slow for our application (datasheet: Enable to COMP active = 540us typ.).
We found a way to enable the TPS54561 faster: pulling down to GND the RT/CLK-pin with a transistor and then release it again for enabling. Question: Is it allowed to pull down the RT/CLK-pin for disabling the TPS54561?
We are aware that this way the TPS54561 operating current is higher compared to disabling it with the EN-pin.
