We designed a custom board based on TDA2Ex SOC with PMIC O917A130TRGZRQ1 part on our design,
Design is validated successfully but below issue is what we are facing.
SOC is booting if you press the power on Button of PMIC manually.
But as per Datasheet First power supply detect event should happen when you apply power to the system and should start.
Now system not starting when you apply the power to the PMIC, It starts if momentary button press on PWRON Pin.
Please suggest is there any other dependency to start system once power is applied to the PMIC,
Please respond ASAP.
Santhakumar.
