UCC29002: calculating compensation values
Part Number: UCC29002
Hi Team,
I am using the formula in the data sheet for calculating the compensation components
My reference design is following  as PMP5326
So far, I can’t get the result of compensation like values in reference design(C55, R67).
If it’s possible, could you please give me an example of  the calculation so I can make sure what I understand where my error is
Thanks a lot,
  • Hello Ajayt,
    If you look in section 8.2.2.4 of the UCC29002 data sheet you can see how the compensation value components are chosen.
    It is important to not that the total loop unity gain crossover must be set at least one decade below the measured crossover of the individual modules.
    PMP5326 does not use the UCC29002. Can you please check this number ?
    John
