Other Parts Discussed in Thread: RM48L952, HALCOGEN, TPS65381A-Q1
Hello
Could you help with following request
I am currently working on connecting RM48L952 dev board with TPS65381 evaluation board and wanted to ask about SPI parity.
I first run HalCoGen demo for “RM48L952_HitexKit” from SafeTI Diagnostic Library and it worked fine, then I moved some basic get and set register functions from SefeTI library to my project, modified my projects HalCoGen configuration for MIBSPI to match the demo and it also worked fine.
My problems started when I modified the HalCoGen configuration to match my requirements. When I enabled Parity in Data Formats tab my communication started to fail. In TPS65381 datasheet (SLVSDJ1A) I found some information about Command parity but none about parity of whole transferred frame.
Is there any way to configure TPS chip for SPI with enabled parity, or is there some other mechanism for checking parity of whole frame (or data part of the frame)?
Many Thanks
Bob Bacon
