TPS544B20: how to connect AGND and GND pin?
Part Number: TPS544B20
how to connect AGND and GND pin of TPS544B20?
  • I'll check this later today and get back to you.
  • From the datasheet:
    "The AGNDSNS pin must be kelvin connected to the AGND pin, with a low-noise, low-impedance path to
    ensure accurate current monitoring. This connection must be made on an internal or bottom layer. It should not segment the thermal tab copper area. This connection serves as the only connection between AGND and
    GND for this device."
    So you do not want any external connection between AGND and GND. It is made internally at the AGNDSNS pin.
