TPS65094: TPS650942
Part Number: TPS65094
Other Parts Discussed in Thread: CSD87331Q3D, CSD87381P, CSD87350Q5D, CSD87588N
We are using Intel ATOM E3930 Apollo lake processor for one of our design. We got the substitute for IDTP9180 PMIC from you, thanks for that. Along with that we are expecting the full power management solution with distribution chips and external MosFETs information (if any). The reference schematic from INTEL uses the IDTP9148 as different power rail regulator. As we are more interested with TI power solutions, please suggest the full set of TI chips (with the substitute of IDTP9148) which can be IDT replacement for INTEL 3930 processors power management solution.
Thanking you,
Regards..
  • Partha,
    Thanks for reaching out on E2E. I have assigned this thread to the responsible applications engineer. They will get back to you shortly.
    Nastasha
  • Hi Partha,
    You can find the TI reference design for Apollo Lake processor in the Intel Document Library under IBL#560683. It utilizes the CSD87381P for BUCK1/6 and CSD87588N for BUCK2 but there are other options, for example the CSD87331Q3D for BUCK1/6 and CSD87350Q5D for BUCK2.
    Feel free to let us know if you have any questions.
  • Dear Kevin,
    Thanks for your quick response. We tried to download the Intel Document Library under IBL#560683( as it is having reference designs and layout guidelines). But there is some problem with the link in intel server itself, it is showing error. Is there any other source to get these references? If yes, please provide the link.
    Thanks again.
    Partha
  • Hi Partha,
    This document is owned and distributed by Intel, you will have to contact them. I will also follow up with Intel on this, thank you for letting me know.
