I am looking for LDO:
Input voltage: 5v
Output voltage: 4v (fixed)
Output current: 0-10ma
Enable control: No
Operation temp: -40 to 85c
Automotive: not must
Cost: very low
CASE: VERY LOW
Similar solution: NCP78LC00 series
Hello Eli,
Wondering if you have tried using the LDO selection page: http://www.ti.com/lsds/ti/power-management/linear-regulators-ldo-products.page# . You can input the parameters required, a list of applicable devices will be shown, and you can easily compare features to select the best device for your design.
Reagards,
~Leonard~
Hi Eli,
Your original inquiry stated "Similar solution: NCP78LC00 series " Indeed, there are no direct replacements for the ON device, verified by the Cross-Reference tool: http://www.ti.com/sitesearch/docs/universalsearch.tsp?searchTerm=NCP78L#linkId=8 .
~Leonard~
