Chemistry updater - sluc564dj.zip
Other Parts Discussed in Thread: BQSTUDIO, BQ27741-G1
Hello team,
After updating the newest chemistry sluc564dj.zip, bqStudio just shows nothing in the chemistry programming tab. Could you help to take a look?
I've following the steps below:
1. Download bqStudio Chemistry Updater zip file (bqStudio Chemistry Updater (Rev. AT) )
2. Open the file and you will see another zip file named "ChemUpdate458.zip" move this zip file to a known location on your computer
3. Open bqStudio, and go to Help -> Update Chemistry
4. You will get an error that says "Automatic update failed. Please try updating using the given zip file" This is normal. Press OK.
5. Find the "ChemUpdate458.zip" file that you saved on your computer and press Open.
6.  ChemID database is successfully updated.
Thanks and best regards,
Victor
