BQ20Z95: bq20z95
Part Number: BQ20Z95
Other Parts Discussed in Thread: BQ34Z100
I am using the BqEasy and EV2300 to program a Bq20z95 BMS.  The factory specification sheet states both full charge capacity (0x10) and remaining capacity (0x11) maximum values as 65535 mah.  At rate (0x04) max is +/- 32767 .  The pack I am using has a capacity of 40000mah.  Any value above 32767 mah causes a runtime error.  Why will it not accept the full charge capacity as stated in the Ti spec sheet for this part?????
I await your best advice.
Paul.
